Boobala
There are no filters in your tanks........... 394358S is a good filter for what you want. Those are the white ones and will let gas pass thru perfect, the red ones are a bigger mesh inside and will let smaller particles go thru..... I order the 100 pack from my distributor and it is a Briggs labeled product like they put on their engines ....
394358S are 4 buxs at a mower shop........
Let us know Mon Ami ~!~!
You have it back-wards Bou... the WHITE ones are for engines WITH a fuel pump ...... read carefully in the description
