Boobala
- Feb 15, 2015
- 7,000
Do you own a similar mower, and if so, can you take a picture of the brackets that attach the deck to the height adjustment system? Also, does this deck look like it would have been original to the mower?
The reason I ask is that there is misalignment between the brackets on the deck and the brackets on the height adjustment system. The adjustable links between the two cannot both be situated on the inside, or the outside, of the brackets. One must be one way, and the other must be the other way. Even so, there is still misalignment, and I do not feel as if the deck is centered on the frame. Something is a bit wonky, but the brackets are not bent, either.
Thank you for your insight on some of my other questions. Now if I could only find the owner's manual...
Might help if you posted some pics of these brackets on the deck ......
