John Fitzgerald
I am seeing a lot of online complaints about failed hydro transmissions, and also some axle problems. What's the weight limit on most homeowner mowers? I am thinking that they are not made for guys the size or weight of NFL linemen. That's a lot of strain on the transmission and rear axles if the design load of the machine is 225 pounds and the operator weighs 325, especially if it's used on bumpy grounds. Commercial grade machines can probably take that just fine. I haven't seen any manuals that address an operator weight limit.
