kblackmer100
If you can move up to a FERRIS you wont be dispointed
Are you sure you MIGHT want a Zero-Turn ..?? Do you use any attachments with your GARDEN tractor.. ( plow, cultivator, heavy trailer loads etc. ) be sure you DON'T limit he capabilities of you new machine, you've been comfortable with a Husqvarna and the Kawi eng. .... perhaps an upgrade into a new Garden Tractor will better suit your NEEDS ! ......
https://sleequipment.com/husqvarna-...MIivyz0Oi83QIVDYvICh1oiQEfEAkYDyABEgIjovD_BwE
https://www.husqvarna.com/us/products/riding-lawn-mowers/ts354x/960430243/#specifications
If you want a long lasting machine you will need to move up a little in your price This is the lowest I would go.
I'll check the link when I'm at home on an unfiltered network. What do you know about the Hustler brand, specifically a Raptor SD?? I'm looking at a 60" model.
Unlike most of the others on here I would not purchase a Raptor SD. I would not even take one if given to me. Lots of reasons you can read about them in the Hustler section.
Up your budget and get a Tiger Cat Scag. It will be the last mower you need to buy. it will last 40 years or longer. Problem solved.
I’ve read about a few disgruntled owners with different issues. What is the biggest reason to avoid the Hustler? Big seller at local chain of commercial lawn & garden business along with Toro.
