DaveyCrockett
I wonder if anyone can help me with a perplexing problem.
I'm working on a Chinese mower Branded BMC Big 20 and it has an engine called Wolf 5.5 HP. Don't let that put you off it's a very standard OHV engine, with a very standard type of carb. It is pretty much the carb used on the Honda GCV160, but it is chokeless. It primes by pushing air into the top of the float chamber, and has very standard looking main and pilot jet arrangements. Everything is clean, armature gap set at 12 thou, compression was 80 psi, before I opened up the inlet valve clearance from 3 to 6 thou and the exhaust from 3 to 8 thou. I don't have any tune up specs on the engine so I'm just going by what I think should work. The engine is pretty new, probably ran for a couple of hours judging by the state of the mower.
It needs a lot of priming for cold start. It advises 5 or 6 pumps. It runs well once started, no hunting or spluttering, but it doesn't wan't to warm start without more priming one or two pumps. I have opened out the pilot jet just a tiny bit but that didn't seem to help. It has an adjusting screw for the pilot system so I knew I could bring it back if I overdid it. The butterfly is wide open on start so I guess it won't pull much fuel through the pilot jet anyway. I swapped the original main jet for one from a Keihin which I can afford to scrap and progressively opened it out until it is visibly larger but still it won't warm start.
I'm a self-taught mechanic and it's business death doing this much work on a customers machine but I would really like to understand how to sort this problem out for my own learning. If I carry on opening out the main jet, I presume eventually it will pull enough fuel to warm start without priming or have I missed something.
Many thanks for any advice on this. I know this kind of knowledge doesn't come easily, so I am very grateful.
