Castlegarden TCP 102. Continuos audible alarm.
Aaron
Hi all.
As the title suggests. My Castelgarden ride on mower is sounding a continuos audible alarm. Not the intermitant alarm which indicates that the grass catcher is full. The warning alarm sounds from the moment I turn on the ignition and only stop when I shut it off. None of the warning lights (battery, grass catcher, oil) are on and everything is functioning normal, engine runs fine, blades engage and drives perfect. If more detail is needed, let me know.
Thanks in advance.
Aaron.
If I am correct your mower has either a six or eight function control board. Each of these functions(low oil, bagger full, etc) is controled by a seperate micro switch. any one of these switches or the board itself could be the problem. You need to disconnect them one at a time and see if you can isolate the problem. below is a link to an electrical diagram that might help. Let us know if any of this helps.
MY PARTSPARTNER | Electrical parts for Castelgarden TYPE 102
Thanks for the reply and the info originalswampfox.
Ill have a tinker with it this evening, ill let you know how i get on.
