SidecarFlip
Don't sound like good QC to me,
On a separate topic, mine is not a push model, does it make sense to exchange it for a push mower? Price is a little higher, but not sure of the benefit, especially if it eats the battery. My lawn is mostly flat and this mower is much easier to manage than my previous one.
They are sending me the axle, no problems there, it'll just take a while. But this morning I mowed most of my lawn on three wheels and it did a superb job even on tall moist grass, where earthwise mower would clog up every few minutes. Very happy with it.[/QUOTE
You will get the replacement part rather quickly. Somehow a 1st GEN (not G-MAX) battery got put in the box with my Snowblower. I sent them an e-mail on the 4th of July expecting a reply the following day. Instead someone from Canada replied almost immediately and got the process of the correct battery going right away. I got the battery sometime Mon-Wed the following week, so it took less than a week to arrive.
Doug
Which Earthwise mower do you own ? Is it one of the heavy 20” SLA battery models that weigh nearly 100 lbs. The Greenworks Li-ion battery models are much lighter, so self-propelled is totally unnecessary on a flat lawn.
Maybe the damage was done in transit.
Doug
It's not bad, actually as easy if not easer to push than the mid 80's Lawn-Boy 21" Aluminum deck mower it replaced.
The GW has sealed ball bearing wheels and only weighs 60.48 lbs. with a 4Ah battery and mulch plug.
The old LB has the bronze bushing mod done to it's wheels so it rolls decent (but not as well as ball bearings) and weighs 58.4 lbs. with a much plate and half tank of gas.
When I bought this house in 1992 at the young age of 29, I used my 1977 Lawn-Boy 7024 21" Aluminum Deck pusher (avatar) until 1999 when I bought the 10323 Self Propelled. I would still switch back-in-forth between my two mowers as the 7024 is just such a joy to use especially now that it has commercial BB wheels on it. Had more yard then too as we had a 20x22 garage and now have a 24x48 garage, wider driveway, and a back patio that displaced quite a bit of lawn.
I do like to push mow my yard every once in a while (got 3 plain push L-B's), but not every week ... more like once or twice a summer. Our lawn is somewhat hilly too, so more reason I prefer self propelled at my age.
You definitely have less grass to cut than me and if it is relatively flat, all the more easier.
I got my pusher direct from GW on a 20% off 4th of July Sale … maybe wait and see if they have a LABOR DAY sale.
Doug
