1947,,,
That is odd,since you changed the dia and the gasket ?? In the right order ???
Bert Is right on a crack on the pickup tube......
OEM parts ?? I change these all the time in my shop and never have issues, unless there is something else wrong.....
Believe me when I say there are other issues when I say something else wrong Mon Ami ......... I dealt with one not long ago, and it was a headache for sure........
I worked on it 3 times before it got right...... It was only a partailly sheared key that caused the issue when it came back the second time.... The key was fine when we got the mower the first time. The governor link was not connected when I took the air shroud off, to check for a mouse nest........
I should have spotted a bad part in the first place.......
Did you take the Air Shroud off and check that the air vane is not blocked or getting hung up ??????
This is a video I made not long ago on that engine when it came back the 2nd time.....
It came back a 3rd time and I found out the problem, FINALLY........
Look at 1:29 at the gov linkage.... It was bent 2 different ways.... Now I am not saying that's your issue, But it would not start cause the linkage was in a bind and it didn't have the throttle plate in the right position.....
https://youtu.be/HejRZItbKCk
Let us Know Mon Ami ~!~!
