Hello all. Gaz here from UK.
My Flymo XL500 fitted with Honda GCV160 is running terrible. It'll start easy but after a few moments will cut out. When left a short spell, it will start and do the same so I'm convinced it's a fueling issue. There is a hose that is off at the minute, it must have popped off at some point. It comes from the pump. It appears to be the vacuum hose as when I suck on it with a pulsing technique, fuel flows rapidly from the fuel supply to carburettor line.
My dilemma is that I have no idea where this hose is supposed to connect engine side. Obviously it will have to be either downwind of the throttle butterfly on the carburettor or on the crankcase side under the piston to sense crankcase vacuum.
Does anyone know where this hose should connect? Inside the end of the hose is a small brass ferrule that looks like it should be pushed in to something.
All the images I have found online show the pump, the hose etc but nothing is giving me a clue as to where it should be fitted on the engine to sense the vacuum to actually make the pump work.
At the moment, I have bypassed the pump and fuel valve just to get the grass cut but certain angles cause the mower to cut out. Any help much appreciated.
