Husqvarna YTH22V46 with B & S...fouls out the plugs & starts missing
golfranch
  • / Husqvarna YTH22V46 with B & S...fouls out the plugs & starts missing
Starts missing after a few mins.....HELP...I put in new plugs
What is your engine numbers, would help us identify which plugs you need. Also, is it carbon fouling or oil fouling?
golfranch
old plugs were wet...briggs model 40000 intec...thanks for any info
You have the mower sitting in front of you.
We have the words you typed on the screen.
If the engine is missing find it :laughing:
If you have a problem you want help fixing, then a full description, starting with the model & code of the Briggs engine then every thing it does, what you see , hear, feel & smell
What you did to the engine last, what the oil level is, what the oil feels & smells like , how long has this been going on , is it getting worse, what grade of plug did you fit, how old is the engine haw may hours on it what type of yard do you have
shiftsuper175607
No extra charge per word here...
old plugs were wet before...new ones?
You went back to old plugs for a check?
The plugs are exactly the same number/brand
Wet plugs is not bad...engine not firing/sparking?
Need more engine numbers
As stated, you must give us more info. We have no ESP and aren’t standing next to you with a drink in our hands. For sure we need the complete model, type and code numbers from your engine. Then give us a better picture of what is happening and what you have done to resolve the issue. You must help us to help yourself.
golfranch
cked new plugs, looked good, loosen gas cap & ran great...amazed....thanks for all who tried to help
