exmark stand on mower 52" model # VTS730EKC524 S SERIES
bhumhrey
my battery light is on and the battery keeps going dead checked at the voltage regulator and no voltage
replaced voltage regulator and battery light is still on. got voltage at wire under plug but was only 19 tested battery at full throttle and it was only 12.4
:welcome:
I know you have problems , the grass is about to envelope you house, the dog has been missing for a week and you are frantic,
However with the information you have posted we can not give any meaningful suggestions.
So lets start with the make & model number of the engine.
The colour of the wires you tested.
Where you tested them ie battery - to purple wire / red wire to ground.
Then what you were measuring AC ? DC ? Ohms ?
