Kohler 27 hp valve cover leaking oil
AULOLYF
2011 Bad Boy ZT 60 with 27 hp Kohler engine is leaking oil from valve cover onto muffler.
Any suggestions for best fix? OEM gasket vs Permatex RTV or Permatex Ultra Black Gasket Maker?
Thanks
Russ2251
Original gasket is best bet. Sometimes making sure bolts are snug will cure the leaking.
RTV should not be used unless specified otherwise.
OEM only. If you have to remove the cover down the road and used a liquid gasket, you will be paying for a new valve cover.
AULOLYF
Thank you. (found the responses in my junk folder. corrected that.)
AULOLYF
Thank for the advice
