blowerhead
After 19 seasons, The threads in the spark plug hole are stripped. Other than getting another head, any suggestions?
Thanks
Thanks
Heli coils are goos anywhere the hole does not need to be pressure tight as the wire insert is a poor fit in the thread.
For spark plugs a similar device called a Time scert is a much better way to go.
Similar idea except the insert is both solid and the correct shape for the plug.
No matter which way you go from now on it will be important to put a little nickel ( silver colour ) anti sieze on the plug to prevent the insert winding out when you remove the plug, particularly if the engine is hot.
g.
Very bad idea anti sieze, don't cross thread the new plug and use a torque wrench if you have one when you install. You should be able to install the new plug with just your fingers and then just tighten to specs. There is a reason the new plug striped out the head. I would price out a used or new head before buying a Heli coil set it might just be cheaper. You will need a complete kit for just one plug, not worth the cost.
