cpurvis
- Aug 25, 2015
- 2,256
The owner's manual for my Kawasaki engine says to change the oil every 100 hours of use and filter every 200 hours. In my opinion, that is beyond insanely stupid! These engines are subjected to extreme duty with heat and dirty environment. If you want to follow Kawasaki's maintenance schedule, that's your choice. I would never want to buy a used machine from you. I don't want to be disrespectful, but to believe that a manufacturer is 100% correct 100% of the time defies logic. It that were true, there would never be recalls.
Do as you see fit. I'm sure you're more qualified than the Kawasaki engineers who designed, built, tested the engine and wrote the manual.
