june151964
- Jul 15, 2018
- 3
I have a 42 inch cut Troy Belt lawn tractor and when you use it to cut with PTO engaged after a short time the PTO shifter shuts off why motor still running
are you responding to june151964Check the battery voltage engine off then again with the engine running.
Should be 12.5 or better off and 13V or better running.
thank you but why would that make the PTO lever shut off
