PapaDonLogan
- Jul 13, 2018
- 3
bertsmobile1,
Thanks for your response. Here's some more detail:
Only fails to crank when hot. Turns over strong (new battery, new plugs). A wait of 5 to 10 minutes cooling usually is enough to start. I drive about 300 yards to gas station and have to turn off engine to refill so this is frustrating when I have to sit a the pump for 10 minutes. Once I start cutting, I don't stop for about 3 hours or leave engine running on short breaks.
No particular smell unless engine gets flooded. Tried with choke on/off, starter engaged for short/longer periods.
Loud sound from flywheel or starter (I think). Almost sounds like metal scraping and seems to "grind" to a stop when ignition is turned off (after attempt to start). This occurs even on a cold start but once it starts (quickly), it runs smooth and at "full" RPM.
I checked the oil level and it was fine. I read that I should clean out the air cooling fan and blades. That makes some since considering the noise per above. Also read something about the pressure in the tank building up greater than the engine pressure if the gas cap air intake is blocked. I'll try removing the caps (2) next time this happens.
I've checked the air filter and cleaned it (have ordered a new one, just in case). The mower/engine is 13-14 years old (bought new in 2004) and has been awesome. The mower is a Cub Cadet KW60 (Tank). Residential use only, but I'm on 5 acres with about 4 acres of grass that I cut weekly in summer and mulch leaves several times in fall/winter.
Hope this helps and thanks again for any suggestions.
Don
Don
