Tecumseh parts for sale. Brand new.
Thanks for the reply to my thread and Yes, I do still lots of parts.
I am not exactly sure what you are looking for, do you have a part number by chance? Is it the rubber hose from
The breather to the air filter housing?
Tecumseh # 33886
Thanks.
Hello I have a Tecumseh carb CA-632569. Supposedly the replacement number is CA-632795A. I need gasket part number 631028A and some other parts.
Do you have parts for this carb? Thank you.
I do have some bowl gaskets 631028.
Thanks for asking.
Four years later ... do you happen to have 35135B? or A? or --?
Hello all,
I have a small chainsaw repair shop and recently purchased the inventory of another local shop that closed up. I have over 1,300 brand new Tecumseh parts that came with the saw inventory. Flywheels , starters, mags, throttle linkage, carb parts, governor parts, cams, housings..........all sorts of items.
A friend of mine told me this was the place to go for anything small engine.
I am not looking to get rich off these, just move them as I will never use all these items.
Please contact me with your part numbers if I can help you out with anything. I will ship most anywhere.
Thank you,
Kent
Hello there.
I have a Tecumseh OH140 eng.#'s 143 680012 in my L&G small Tractor needing these parts (I think).
!. is a #610906 SSI Magneto ( 20 amp system I believe).
2. is a # 610988 Rectifier regulator.
3. is a #610902 Alternator Coil Assembly.
