Jelly Roll
- Jul 11, 2018
- Threads
- 1
- 3
I've been lurking around here for many months as I have been trying to educate myself. Very helpful information.
Quick notes about myself.
Own 7 acres, and cut 3.5 of them with an MTD 38" lawn tractor. Yep, you read that right. Used it on our previous home which was 1/4 acre and it performed great. I've used it for the last year at our current home and it's still trucking. I mow anywhere from 3-8 hours every weekend from April through October. So, I REALLY need a bigger mower.
The only local dealer that I feel is a good fit sells Gravely, Hustler, Scag, and Toro.
My budget is $4K. I know that puts me in a residential line. Would love a step above this threshold, but it just doesn't fit the budget. Besides, if my current MTD can manage this place, I'm quite confident Hustler and Gravely can out last the MTD.
My dealer showed my the Hustler SD 54 and the Gravely XL 54 (I had looked the Gravely ZT 52, but it was just too far out of my budget).
Anyway, the only differences he could offer were the Hustler's rear tires are 2 inches wider and the Hustler has the Kawasaki and the Gravely has the Kohler. I'm not convinced one is better or worse than the other. I hear and read plenty of debates. You might drive a Dodge, but you couldn't give me one. Right?
The price was almost identical (within $100), so it was hard to decide. Then, I kept reading on here about spindles. So, I had the dealer show me the spindles side by side. The difference is huge. Hustler's spindles are cast aluminum and much heavier than Gravely's (which are painted and appear thin walled and lighter).
So, it looks like I'll be coming home with a new Hustler SD 54.
Any comments on things I need to do first, or check, or whatever? This is my first zero turn.
Thanks again for all of the education over the last several months.
Jelly Roll
Jelly Roll
