solenoid replacement
Cmancil
How do you get the old one out???? No where in the 45 dollar tech manual ?
Drop your drawers, hold your nose bend over and blow hard.
The above of course assumes you sat on it & it is stuck up some where that the sun never sees.
As for replacing one on a mower, it would help if you told us the make & model of both the mower & the engine.
Also weather it has a remote solenoid or has one on the side of the starter.
Cmancil
Ztrack. 335e 20 hp. Remote location under seat near fuses
BlazNT
1. Disconnect positive battery cable from the battery.
2. Mark wires so you will know where they go when you put them back on.
3. Take pictures. So you will really know where they go.
4. Remove nuts holding large wires. Remove wires.
5. Unplug two small wires.
6. Remove two bolts or nuts holding solenoid on.
7. Remove solenoid.
Cmancil
Solenoid is in small cavity. Can't get to two nuts that hold it to housing. I tried working from underneath. I will send pics
BlazNT
One more post and you will be able to post pics.
shiftsuper175607
you will need to buy a set of deep sockets.
probably 1/4 inch drive...
I always enjoy a reason to buy new tools!
