Just need to get a few things clear
1) are you running with the throttle wide open all the time
2) are to trying to mow 12 " while traveling at full speed on the sticks ?
I regularly mow 3' yes foot tall grass with a old 8 Hp without any problems other than deck choke requiring me to reverse regularly to clear the discharge chute.
However this has to be done at a crawl, which is easy on this mower as it has a 7000 series Peerless box but even then I have to slip the clutch a little in the reeds & Tussock grass areas.
Unless you are doing a finish cut of 1/2" or less. full speed on the sticks is for getting to where you want to mow, not mowing.
Next is the blade , high lift blades can gobble up near twice the Hp as strait blades.
The engine is just one side of the story.
What is it sitting on ?
How big is the deck,
What blades are you running\
Do the spindles have spacers under the blades to change the blade height inside the deck ?
Do you have bagger on it, a restrictive discharge chute, no chute .
Lots of posts here from owners who had to open out the discharge chutes on bigger decks because the hole was so small it kept too much grass under the deck.
