John R
- Mar 9, 2016
- 240
Possibly didn't put cam in correctly .
Be my first guess too
OK, so now it is not running very smooth and sometimes keeps running after I turn off the key and even backfired once. The only thing I did, as far as adjustments, is to adjust the valves to what I thought they should be. Could that be the problem?? I put everything back just like it was originally and only readjusted the valves(which probably didn't even need it. I used ..003/.005 & ex. .005/.007. Any suggestions before I start readjusting again? Seems to run hotter now than before also.
Thanks
