ONTHESTRINGER
Sounds like you need a sickle bar instead of a lawn mower. :laughing:
Need a yard boy!!!!!!!!!!!!:laughing:
Sounds like you are saying Toros are perfect for idiots. :laughing:In response to the comparison of John Deere vs. Toro, I should first point out that I am a lawn mower mechanic for a Toro dealer and I my primary responsibility is home owner riders, both Z's and the traditional garden tractor. I also do some new mower setup and some sales.
The homeowner deck is stamped as is the frame. However Toro is the only company to use high alloy American steel. Other companies use sub tubing with stamping but use the low quality steel made in China. I should point out here that we do not sell the garden tractor variety of Toro as we know they are made in China.
As for the greasing issue with zerks. It has been my experience that the vast majority of home owners do NOT grease their machines. An unofficial survey of our customers reveals that most do not even own a grease gun. I find in servicing machines that most owners do not even clean their air filters or check their oil. So having zerks in not an advantage. I believe sealed bearings on spindles and axles and even front forks is preferable. No service needed!
I believe that the John Deere home owner series is produced in China.
As for cutting, the Toro Z series (Timecutters and Titans) are new this year so did not make Consumer Reports. However the decks are the same as last year and last year that were at the top of the chart in cutting (amongst a lot of other things as well).
I apologize if I have sounded offensive in any way. I'm going by my observations and knowledge gained by working in and observing the industry every day.
Hope this helps!
Yea I understand where you are coming from.Nope, just a really great product line for people who don't want to spend all their free time working on their lawnmowers! :smile:
Hope this helps!
Well I bit the bullet and purchased a DC 3374 today. Getting it tomorrow @ 11am ---- hopefully it will last a long time!!! It came stock with a Amsoil bypass filter, screw on oil filter, & screw on filters for each drive motor (5YR Warranty) ! Each drive motor/pump has it's own oil cooler & and engine oil cooler. Everything is greaseable!!
