Black Bart
- May 4, 2011
- 550
When I was shopping for a new mower this spring I looked at them for how easy they were to service.
The Toro does not have a frame it is like a unibody they stamp it from a large sheet of metal.
This makes it difficult to service.
The Simplicity has grease Zerk's on the deck but they are underneath and you must jack it up and lay under it to grease the deck.
The JD EZ Trak has a foot plate that is hinged you just swing it up and it exposes the whole deck.
Grease Zerk's are right on top and real easy to access.
Where the others had a plate bolted down in the rear the JD has a large plate that is hinged and the seat is bolted to it.
You just fold the seat over and you can pressure wash the pumps and drive motors.
JD is by far the best design for easy servicing.
From what I have seen the JD has a Superior cut over most others also.
If I decide to sell my JD I will get a better return on my money than anything else that I could have bought.:thumbsup:
When you consider things other than the original cost then JD Begin's to look really good.
Buy from a nearby reputable dealer you don't want to haul it 50 miles to get parts or service.
