In 1953, a fledgling company called Rocket Chemical Company and its staff of three set out to create a line of rust-prevention solvents and degreasers for use in the aerospace industry, in a small lab in San Diego, California.
It took them 40 attempts to get the water displacing formula worked out. But they must have been really good, because the original secret formula for WD-40ョ謡hich stands for Water Displacement perfected on the 40th try擁s still in use today.
Convair, an aerospace contractor, first used WD-40 to protect the outer skin of the Atlas Missile from rust and corrosion. The product actually worked so well that several employees snuck some WD-40 cans out of the plant to use at home.
The Vice Grips hold things together while the JB-Weld hardens.(then take them off)
What in the world are you fixing with JB weld and vice grips sheet metal? I have used it to tighten bearing races or as a filler. Sure is a good fix for thing I haven't tryed.
How about Zip Ties ?
MUST have Crescent Wrench (for younger guys - adjustable wrench :biggrin![]()
