Tecumseh parts for sale. Brand new.
Good. But I have yet to find the model number on my 10 hp horizontal shaft engine.
Hello all,
I have a small chainsaw repair shop and recently purchased the inventory of another local shop that closed up. I have over 1,300 brand new Tecumseh parts that came with the saw inventory. Flywheels , starters, mags, throttle linkage, carb parts, governor parts, cams, housings..........all sorts of items.
A friend of mine told me this was the place to go for anything small engine.
I am not looking to get rich off these, just move them as I will never use all these items.
Please contact me with your part numbers if I can help you out with anything. I will ship most anywhere.
Thank you,
Kent
Hi are you able to supply any parts for the Tecumseh 5hp series 6 carb
I do have many , many carburetor parts,- kits, gaskets, needles, seats, springs, choke rods, linkage ..........
If you have specific part numbers I’ll be happy to check. If you have a carburetor number I see what I have for that carb.
Thanks
Hi thanks for the reply here is a list of Carb parts required
632433A
631028A
6321021B
510342
510341
510343A
632755
Any help would be very much apricated
Many thanks
Stephen
632433A
631028A
6321021B
510342
510341
510343A
632755
Many thanks
Stephen
I'm afraid I am not much help, even with almost 1,500 parts.
632433A - Do not have any left
631028A -I have 3 of 631028, gasket
6321021B - can't find that number but I have 2 of 632102, adj screws
510342 - Do not have any left
510341 - Do not have any left
510343A - never had any
632755 - Number doesn't show up?
Are any of these parts available in rebuild kits? I have quite a few of those.
Thanks Stephen
many thanks for the reply sorry I gave you a wrong number on one of the items the carb service kit is Tecumseh Carburetor Repair Kit 631021B
RepairClinic Item #1606506 | Tecumseh Genuine OEM Part #631021B
thanks
Stephen
thanks
Stephen
I have those kits as well, I have 2 OEM Tecumseh and 3 in Oregon aftermarket.
So, I have 632102, and 631021B. hope that helps,
let me know.
Thanks
Hello all,
Thank you,
Kent
Do you by chance still have parts???
I have a TVS120-63079e and am looking for a EGR. I think i only need the rubber hose being the problem is that it leaks at the block not too much blowby, etc.
TIA
TIA
Thanks for the reply to my thread and Yes, I do still lots of parts.
I am not exactly sure what you are looking for, do you have a part number by chance? Is it the rubber hose from
The breather to the air filter housing?
