bcollins3481
- May 26, 2018
- 5
Hey everyone! I have a few years old Cub Cadet wide area push mower [CC760ES (12AE76JU010)]. It has been giving me issues since the middle of the last mowing season.
What started to occur was the mowing operation was going like normal but after about 2 hours into mowing (just about done with my yard), it started to surge and then eventually died. I have to let the mower cool for a bit before I can start it unless I open the choke, which works for a bit but then eventually wont run at all. Over the last year the symptoms have just gotten worse, I'm down to about 15 minutes of mowing. The heat does seem to affect the mowing time and also how long it takes before I can mow again.
At first, I changed the oil and spark plug. While I changed the spark plug I used an aftermarket product that is meant to clean the engine by spraying into the spark plug cavity with the engine off and then wait 15 minutes before you start the mower. When the engine was started I was sure to believe the EPA was having alarms going off to send a helicopter, luckily the black smoke died before they arrived. This process didn't seem to do anything.
This year, I have changed the coil assembly, the coil assembly charge (part under the flywheel), new air filter, new fuel line and fuel filter. I also removed the carburetor and it was clean as a whistle. I don't know about the tiny valves being clean but the bowl was clean. I tested the fuel solenoid and it retracted fine while it was cold. What I did notice though was the o-ring on the solenoid was broken apart so I replaced it.
The most important detail I can think of though is when the engine starts to surge, I can very gentle apply a little of the choke and it steadies out. However, this only works for say like 5 minutes, basically enough to turn the mower back around and head toward the house so I'm not pushing it down the street like an idiot.
I have tested the gas cap vent too by running with it 90% off, didn't make a difference.
My extremely patchy lawn is getting more than usual looks from my neighbors, any suggestions would be totally awesome. Otherwise, I will be on the mowing 1/7th of my yard everyday of the week.
