Sorry about the red herring. no Idea why I wrote Toro in place of Simplicity.
The bit you remove is the large cover usually held on by 4 bolts, two at the front & two at the end.
None of them need to come out as the holes are slotted so undo them 3 turns and the top should pull off.
