Ric
Should it be really dark, like dirty car oil (almost pitch black), or just a bit streaky with brown/black ?
Thanks in advance.
What oil looks like when it's due to be changed depends on how much the mower is being used and the conditions it's being used in. If the mower is being used in extremely dusty conditions you'll need to change more often.
You can change your oil once a month and have it be almost pitch black regardless of the type of oil you use, regular or synthetic oil it doesn't matter.
Someone asked How many hours do you typically put on your mower per season? If you're a person who typically mows once a week for an hour to an hour and a half then changing your oil once a year would be fine.
