jtnewhouse
- May 12, 2018
- 7
So the logical thing to do is to go back and carry out the two tests asked for in post # 5.
To put a really silly spin on things but hopefullly illustrative.
Pulling up on the wheel and moving back in the seat changes the weight distribution on the mower, combined with a slightly underinflated rear left tyre causes the mower to tilt ever so slightly which changes the angle on the float bowl allowing the float which is just fouling on a badly cut gasket to free itself and cut off the fuel at the proper height.
I could come up with a dozen or more such but I would hope just one will suffice.
Mysterious problems can always be fixed by going back to the basics.
And when going back to the basics identifies what is really causing the problem you then look at the mower to try & understand what pulling on the wheel was actually doing.
In most cases that would be true. But to be completely oblivious to something that you discovered to have a direct correlation to the mitigating of a problem would be what? Reckless, stupid or Ignorant? I could come up with a dozen or more such but I would hope just one will suffice. I never deviated from "the basics" I merely pointed out items that were worth mentioning. And I was able to find a piece to place in the end of the solenoid to keep it from extending. Which, turns out is not the problem. And yet another day spent with my tester going from connection to connection. Oddly enough, I did notice that, (i'm not making this up) the onset of stalling is significantly more prevalent when turning to the right, not left (uphill primarily). And to save you from accusing me of another asinine, concocted brilliant diagnosis, I'm not claiming that the tractor can be fixed by pushing on the steering wheel and only making nascar turns (left).
