TheRiflesSpiral
- May 17, 2018
- 19
Hello!
New owner of used Bronco (13AJ609G766) with weird problem...
When I first brought the mower home, it wouldn't run unless I had either the brake or the gas pedal pressed slightly. With the key in any position, drive in neutral, the motor would cut out if I didn't have my foot on either the brake or gas. (This might be by design? I can't find a reference to it anywhere in the manual)
After a few uses, though, the motor would cut out badly... every 10 feet or so, it would pop or backfire as though the ignition was being intermittently disconnected. On a hunch I put a little pressure on the brake: lo and behold, no more cutting out! So as a temporary measure I disconnected the brake (at the rear pulley) and wired the brake pedal so it's always "braking". That fixed it for a while.
Now it's started to do it again, no idea why... It will idle fine, has plenty of power, moves around properly and the stupid reverse switch thing works properly but it's cutting out just like it did before.
Maybe this isn't the way to fix the issue but: is there any way to just disable all that electrical crap? It would be great if I could just turn the key, engage the PTO and go!
