omerta14
"I really enjoy the challenge of fixing things."
omerta14- for starters, u can run the valve seal test without the ignition coil- obviously it just won't fire but it might tell u why it won't start. If u *REALLY* want to fiddle more with it, I actually came across a 10hp tecumseh similar to yours (just no OHV) where the ignition coil post also broke off. If there is some post left, on mine i filed it down just so it is flat and tapped the post (be careful not to drill through into the cylinder) and added a spacer. Get longer (10-24??) screw thus 2nd post back to hold the coil. I used it for a few years(left it with the apt building when i sold it.) If you can find someone, u can also weld on the broken piece (shows welding is the one equip i dont have).
Like the *REALLY* in your reply...When I saw that post brake I almost tossed in the towel lol. I like the idea of trying to flatten out the post and tap... will test the valve seal as mentioned because if that is hosed, not sure its worth pursuing this any further...
Thanks for your feedback.
Mike.
