curmudgeon555
- May 9, 2018
- 23
Believe it or not, this is the first ground drive belt replacement since this mower was bought new!
Have replacement 82" belt but cannot get enough slack to get over both engine pulley at front and transaxle fan and pulley at the rear. And that's skipping the two idler pulleys.
Do I have to remove the engine pulley? Manual just says install belt on forward engine pulley and then pull slack to rear placing over fan blades and onto transmission input pulley.
Doesn't work for me.:thumbdown:
Suggestions?
Suggestions?
