Boudreaux In Eunice La.
- Jul 22, 2017
- Threads
- 21
- 2,154
I got a story to tell about a mosquito leg in a carb ~!~!
I have a 440000 series B&S V-Twin in a Toro Wheelhorse that's giving me some trouble.
From cold it starts fine and cuts quite tall grass ok. However after about 40-50mins or running it bogs down/looses power. If I'm quick and turn off the cutter and drive the revs will come back up. Sometimes that doesn't happen and it will stop. It can be restarted again immediately. Sometimes if I give it a 3 min rest it will carry on for another 15-20 mins and bog again. Sometimes it bogs down again almost immediately and I have to give up and pack it away.
Next day/week it will be fine and do another 45 mins work before going on strike again. The thing is it never packs up after say 10 mins so it's not just a case of it failing when warmed up. It takes longer than that.
I think I have ruled out:
Blocked fuel tank air vent.
Coil or Diode breakdown (replaced with new)
Spark plugs (replaced with new. Old plugs look clean, not oiled)
Fuel filter (replaced with new )
Fuel pump (replaced with new, including the pipe from valve cover to pump)
Valve guides moving in the head (They seem fine - all look same height)
Engine oil was replaced last season and still looks quite clean.
I'm beginning to think this is a fuel, carb or governor issue. Got any tips on how to narrow the problem down further?
I've noticed that the transparent fuel filter is never full of fuel, it always has a large air bubble in it. I've tried filling the filter with fuel using a syringe and it stayed full for one session. Today when I looked it was mostly air again. Any thoughts on how air is getting into the filter? I can't see any fuel leaks but perhaps I should just try replacing all the hoses anyway as they aren't expensive?
Ok are you sure you are running on both cylinders all the time ???? Those V twins will run on one and then die out when you engage the blades........
I'm sure this has nothing to do with it, but since you've tried most everything that is an apparent cause, have you checked the fuel filter for the right MICRON size ..?? some filters are required for certain engines, read the description of the filters... and also here's some info on that "trashy" fuel line stuff.....
View attachment 37612..View attachment 37613..View attachment 37614
