reynoldston
Check with mower salvage yards. I installed a good used one in a JD180 ,paid 150 for it.
ACCORDING TO THAT DIAGRAM..IT LOOKS LIKE YOURS TAKES GEAR OIL...IF THATS TRUE ..DRAIN IT AND SEE IF ANYTHING IS IN THE OIL FIRST..THEN WE CAN GO FROM THERE:smile:
one last thing we haven't touched on ..is the belt....if your clutch pulley arm isnt moving all the way..it could cause this...put clutch in and set park....check to see if you can turn the trans pulley without the belt holding it...[ you should jack up the rear so the tires are off the ground and its in neutral ] try this before the oil..:thumbsup:.............heres a picture of the trans pulley with hitch plate removed
Something definately is bent or clogging the gears. forcing it could cause more damage if it's something inside the tranny. I heard it from someone that the lower end husqvanas had bad gear trannys, and I'm pretty sure Husqvana makes poulans and craftsmans now.
I would suggest looking on poulans site for a transmition diagram, and if you can't find it there you may be able to find something on craftsmans website.
