JonnyBlaze
It's still only turning over 1 revolution at a time with the key. When I remove the spark plug, it turns over like it should. Battery and everything is good. Not sure what problem is.
Lol:welcome:
Pull the rocker cover off and adjust the valve lash.
They get bigger over time and that defeats the decompression .
The starters are weak on mowers and can not overcome full compression.
Yes. I did.John it's got to be something to do with that compression release, connected with the valve-train components, including the camshaft, you did get the timing marks on the crank and cam lined up .. RIGHT ??
How do I know that I'm on the compression stroke?In your last video you posted the exhaust valve wasn't moving to release the compression. There was no bump on the exhaust valve on the compression stroke. To it to top dead center on the compression stroke loosen the valves. Remember the exhaust is on the top and intake is the bottom on the s's. Readjust the valves. You might have adjusted them on the wrong stroke is what might have happened or the cam is installed wrong. Intake .003 exhaust .005
