Ariens A19A42
RON, DID YOU NOT watch the video I sent in POST # 26 ....???????????? THE LINK !!! CLICK ON THE LINK
IT EXPLAINS WHY we do NOT use the 1/4 inch after TDC method !!
HERE IS THE VIDEO >>>> AGAIN !!! .. ... ... https://www.youtube.com/watch?v=dWHPHGZAvj4
IT STARTS at about 19 minutes & 06 seconds into the video !!! ( it MIGHT start at that point .. I reset it to that point )
AND HERE IS ANOTHER VIDEO of how to ADJUST THEM........ WATCH THESE VIDEO'S
https://www.youtube.com/watch?v=8PEUt_KAcYk&t=21s .. ( watch THIS ENTIRE VIDEO )
GET THIS 1/4 TDC idea OUT OF YOUR HEAD !!......... YES the valves are adjusted separately as shown in the video !!!!!!
IF you don't understand any of this .... post it.... and I will send you my phone # in a PM, .. and try to talk you through this !
I did adjust them that way but only had gauge with the thinnest of 8 thou so used a piece of printing paper hoping it was about 4 thou thick but it turned over one time good then won't turn over again like that. So another gentlemen sent me a private message and said its a must to use the 1/4" below TDC to adjust them. I just bought a new feeler gauge with 4 thou so will try it again.
So have to talk puppy for a walk then when I return I'll try it again plus take the hood off so I can do it easier.
Thanks for your help.
Ron
