Boobala
Ariens, THIS is bewildering us also, this is a head scratcher, IF you have fuel reaching the cylinder, and you have good spark, along with correct timing, by all accounts it SHOULD run, you say you can't turn it with the plug in ?? THAT sounds like something is stopping rotation, even with the plug in, it may be HARD to turn, BUT you should still be able to turn it by hand, something is blocking something, ..... check the spark-plug to see if the gap is closed ( piston hitting the plug) it sounds as if the air in the cylinder cant escape, that would make me think, (SORRY) incorrect valve adjustment, plugged exhaust port, and or breather, .... trying to avoid going into the engine, as a last resort, let us know about the plug as we ponder over this.
