LarryJohnson
- May 30, 2017
- 142
I think we are a little out of sync.
If a motor has difficulty cranking with the spark plugs in but cranks freely with the plugs out then that indicates that the valve lash is not correct or the inlet pushrod has fallen off the rocker.
That makes sense. I’ll try it tonight. I didn’t understand your last reply due to verbiage and typos. Thanks
