bhrodriguez
- Apr 19, 2018
- 1
I have a troy bilt 42" cut. The motor turns over but then stops and I hear a whining sound. I have replaced the start and a new battery. I still get the same results. What should I check next?
You need to look and see what it's doing. I would pull the engine shrouds to get a good look at the flywheel ring gear and starter to see exactly what is happening. Is the starter gear not staying engaged with the ring gear? Are there missing teeth on the ring gear?
