ekywildcat
- Apr 11, 2018
- 17
I looked up the price of a new cam, around $70 on Amazon includes lifters too. Cheaper than I figured. What was interesting though, in the picture, when you browse over it and enlarge the picture, the lobes are installed on the shaft on splines! I guess that is what Tinkerer meant when he said it was made in segments. I'd say that's my problem, splines are worn throwing off the timing or lobes just wore out.
I found some used engines for $100-$150, may go that route if I can hear them run. Question, some of the engines had a different shaped blower housing, are any of the OHV Briggs in the 14-17 hp range better than another? TIA.
