 - Nov 29, 2014
- Threads
 - 65
 - 24,995
The whole set up relies on the belts being exactly the same width.
As the long one is now thicker than the short, the short belt will always be turning faster than it should.
Net result is the range of speeds changes quite drastically.
Some times they won't go on the slow settings and other times they wont go as fast.
The top belt tension is fixed by that !#*! spring.
The pedal changes tension on the bottom belt which of course has to work against that !#*! spring.
When that happens the middle bit moves and thus one belt sees a bigger pulley and the other a shorter.
It is a finely balanced system.
So if you have the "gear" steps don't be worried if you get no drive in 1 & 2 positions.
If you find it a problem then you know how to change the top belt now, it is the easier one.
Generally customers think I am trying to pad out the bill when I tell them both have to be done.
So I just change the one.
Usually before the season is out I get called to change the other one so they pay a lot more labour.
And congratulations once again.
Tripple check that belt run before you fire it up.
It is very disappointing that whoever sold you the belt did not suggest doing both belts
