Tinkerer200
Crazy question, should the flywheel and or magnet be grounded? they both have ground to battery.
They are fine, not the problem UNLESS the flywheel magnet is weak, not likely. Is the starter spinning the flywheel at a good clip? Some say it takes 600 RPM to fire the CDI coil, I have heard 800. See if it will start with one plug wire disconnected. They will run on one cylinder.
Walt Conner
