cruzenmike
https://weingartz.com/expert-advice/2017/08/lawn-mower-engine-overheating/
Check this article out. The section on low oil level got me to thinking... If the engine you have uses pressure lubrication, is it possible that your oil pump has failed? If oil is not getting to the top of the cylinders, the heads would get extremely hot resulting in your hot muffler and melting plug wires?
