Repairs Goes slow then stops
Vulnavia
During the winter, when plowing the tractor would go slower and slower then would not move unless I was gentle on the pedal, letting off then gently pushing the pedal. Continued to get worse until it will barley move ... 5 feet then stop. The pedal would go "to the floor" never did that before. Belts are relatively new, springs pulleys seem ok.
Any Ideas ?
Thanks,
Will
Any Ideas ?
Thanks,
Will
Post the machine's information so we can tell what we are working with see example .......
Well this is going to be fun cause it is a vari drive model and Cub have neglected to put that page in their parts break downs.
The drive to the rear is done by 2 belts, you will need to remove the battery & battery box to see both of them.
It works by the middle bit of the double pulley going up & down which changes the diameter of the two pulleys.
In principle the same as a set of stepped pulleys you see in bench drills & lathes.
In your case I would suspect it froze or jambed in the slow position.
The speed change works by your foot counteracting a spring which could also have broken or fallen off
Not excluding a buggered belt.
If either is damaged both must be replaced.
