Hello,
I received my Ariens mower delivery yesterday. It was the 52" Ikon X Zero Turn with the Kawasaki FR series motor.
This happened before work, so I quickly started it, let it idle and run for a few mins. I used fuel from a gas can that was probably two months old premium, and only used a small amount of it. Anyways it started up easily and worked great.
Then 8 hours later I came home and wanted to use it. It cranked but wouldn't start. I added fresh premium gas. Checked obvious connections under the seat and didn't see anything. The safety features seem to work. As in no cranking without being in the seat or having parking brake on, etc.
I put it on a battery tender overnight in case the battery was low.
This morning the same issue. Cranks but won't start. Nothing has changed since delivery on it, and I'm doing the same actions for the "Start engine" process.
What do I need to start checking before I have to load it on a trailer? Bad fuel maybe? Is there some electrical kill switch that could be activated?
