cpurvis
Many people believe that 'commercial' operators, i.e., those that use their equipment every day, put their equipment through more strenuous paces than the non-commercial user.
I don't believe that is true.
They run their equipment at wide-open throttle; so does the homeowner.
The difference is that they use the equipment more hours on in a day than the homeowner. But that isn't a bad thing.
In 8 hours of run time, the commercial mower will barely get a chance to cool off. That's basically one thermal cycle. In 8 hours of run time on the homeowner's equipment, it could be four (or more) thermal cycles. Once an engine is up to temperature, very little wear occurs. Also, the homeowner's equipment has enough time between cycles that it "drains dry," that is, the lubricated wear surfaces of the engine have had days to shed their oil coating. That's one of the reasons why the saying "sitting does equipment no good" is true.
