johnorlandi
Hi new to this forum
I have a 5 HP B&S engine model # 133432 type 00036 08, code 94081807
I have no spark, I replaced the coil with a B&S new armature magneto#397358 purchased for Jacks small engine.
I also replace the key and cleaned the flywheel
Still no spark
I connected the coil wire directly to ground and no spark, hooked it back to the switch still no spark.
compression is very low, ready to return the coil back to Jacks and purchase a Harbor Freight predator 6.5 hp.
Disconnected the low oil sensor
Any ideas what to check next
Thanks
John
Still no spark
Thanks
John
