TylerFrankel
- Feb 25, 2018
- 27
Hello all!
I have a Coleman Generator that I am working on for a friend, it's 2.6HP OHV and I believe its 2000Watt. It would not start when they gave it to me, so I first checked the spark plug, and it's fine. My next step was to try and feed it fuel directly through carb air intake, and sure enough it fired up for a few seconds until the fuel ran out. So, this lets me know somewhere between the tank and piston the fuel is blocked. I suspect either the fuel on/off switch, fuel lines themselves, or carb, are clogged. However, I can't get the fuel line off the carb because it has sort of dry rotted on, so I have no way of testing which part is faulty. Any suggestions on what part is bad and/or how to get this fuel line off of the carb? Any help appreciated, thanks!
