BlazNT
A friend of mine had a load handler. Not bad really but you usually need to dig out in front of the wheel wells or the material can get locked in place and then the mat just pulls out from under it. For commercial use would definitely want the heavy duty model.
With some added 1x12 boards put in place so nothing will get to the places you talk about it could be an easy workaround.
