Briggs engine won't fire after new piston rings on Craftsman mower---15.5HP
  • / Briggs engine won't fire after new piston rings on Craftsman mower---15.5HP
I got a compression tester and it read 125. I have not adjusted valves yet. I read on B&S website that they don't publish compression PSI, that they prefer a leak down test. Does this 125psi sound correct? The flywheel is turning and I wouldn't think that it would turn if the key snapped off or fell out, would it?
125 psi is high, so check the valve clearances to start with. The engine will crank with a sheared flywheel key but will not fire at the correct time.
Luffydog
Possibly didn't put cam in correctly or the rings but thinking the valves is where u should start first before another tear down.
Ronno6
Check that your muffler didn't get plugged by some critter during your rebuild.
If it can't exhaust, it won't run.
Ever pull the potato up the exhaust pipe trick?
theticket
I thought 125PSI was high also after reading other posts. I will check clearance on valves and check muffler for blockage before tearing back down. I will repost on results.
Thanks a bunch to all.
theticket
Sure enough, the key sheared off. I will get another one. Any advice on how to prevent this from happening again. Is there a correct way to insert the key to make sure it won't shear off again??
thanks for all the help
Make sure it's torqued down to the right specs.......... If the flywheel is a lil loose it will shear the key right away...........
A taper needs to be clean & dry to lock in.
It also needs to be a close fit.
If a little lip has formed on the edge of the keyway on either the crank or the flywheel it will need to be removed or the taper will not lock no matter how tight you do up the nut.
theticket
OK< thanks for the suggestions. I'll give it another go!!!
theticket
OK, new key installed and flywheel torqued properly and everything is working like it should so far. Thanks to all!! I learned a lot....
:cloud9: :banana: :drink:
